This is the helmet for a baikers group!
The resolution is:
Nozzle: 0,4mm
Layer thickness: 0,2mm
Infill: 80%
Quality: Normal
Time: 6 Hours
What do they baike there?
Decent print quality, a model like that needs soluble or break-away supports though.
@Adam_Steinmark hello
@Kevin_Danger_Powers I read it as “bikers”. Hence the helmet.
@Adam_Steinmark I know what he meant. I was just giving him some crap for his typo.
How about impact resistance? I want to print a helmet for bicicle but dont know how tick it should be
@lightshadown That’s probably not the best idea
Oh I dunno… with proper engineering I could see a 3d printed helmet filled with EPS foam being crash worthy. Modern biking helmets are simply that actually. A thin plastic shell over a well designed foam core…
@Eric_Cha I could see that, but a solely 3D printed helmet would not work well.
@Nathan_Walkner I’m assuming that the outside surface is the most important, if you flip it the surface will me marred by support structure.
