@TeamDogoman_Rc here are some pics of the front axis. I have seen that when is turning right the servo saver lifts a little bit. Maybe it’s that what is the root cause of the problem.
Pic 1&2 right turn
Pic 3 left turn
Pic 4 neutral
Pic 1&2 right turn
Pic 3 left turn
Pic 4 neutral
Ok that could definitely be your problem. Try lifting it of the ground then give some steering input. Does it still do it?
@TeamDogoman_Rc It seems that I’ve been able to fix it. I just use some sand paper in the servo saver and move the servo horn one teeth back. Thanks!
