Started thinking about a DIY table for the laser but I didn’t found the info on the website, what is the weight of the machine ?
1216x766x453mm is still the official size (w/ exhaust, pipo, etc) ?
Will get the measurements for you, Weight of the machine less somewhere around 40kg. I am able to lift it on my own. (would not recommend it) with two people it is easily moved.
Need to find a good way to weigh it.
Size, 2 secs lets get some new dimension renders
@Maxime_Favre1 hope this helps, if you need any other dimensions give me a shout
@Bonne Wilce perfect, thank you.
Forgot to add there are 4 sets of mounting holes on the side of the machine so you can bolt it down with an l bracket or simular
Next questions about the exhaust fan:
Any recommandation about the fan flow ?
I have access to nice and quiet inline turbines from 190 to 1250m3/h.
The exhaust on the machine is still 100mm ?
