SOLVED
Hi all!
I have a little problem with Laserweb 4.
In the control page I cannot move the pointer with the arrows and the position display doesn’t changes (but in the bottom-right command window I can see the jog commands). Even the “run” command doesn’t send any command to GRBL and no commands in the window.
I checked all setups and obviously I connected a GRBL 1.1 board.
I tried to load other versions of Laserweb, back to 4.0.728, and all versions have the same behaviour.
So, I suspect that here is some setting file that is corrupted or incompatible (in the past I tested older versions), but I cant find such files.
Suggestions?
Thanks in advance.
(OSX 10.12.5)
