So power consumption has always been a challenge for me to understand. I’m currently making a new Top Hat with 6 strips of LEDS, 94 pixels each. I’m running it from a Bluefruit Feather and the strips are drawing more power than the controller allows (I think).
I have the brightness set to about 30% and even still it draws on average around .50A but I’ve seen it go as high as .75A. When I have the controlled powered via the USB port, it goes thru a couple of the phases but then resets itself. Via the 2400mAh lipoly battery, it doesn’t reset but I’m afraid its pulling more amps than the battery likes and I don’t want to start a fire inside my hat.
I have 2 Tenergy 3.7V 5500mAh batteries with continuous discharge of 1100mA, which should be more than sufficient (I think). I was thinking about using those but I’m unsure how I should connect them to the strips and/or controller. I’ve never had to use 2 batteries on a single project before. And I think there’s issues with connecting these types of batteries in parallel vs series.
Again, appreciate some advice!
TIM
