So playing with my replicape today. While having it open all was working all okay and motors were moving. Now once the printer is all together, on first start the motors do their singing and then nothing. I can login to the BBB and I can access the web interface but it seems no serial port exists even though it did while spread out all over the desk.
It is able to see the cape so not sure what the hell is happening
[ 3.267160] bone_capemgr bone_capemgr: slot #0: âReplicape 3D printer cape,00B3,Intelligent Agen,BB-BONE-REPLICAPâ
can you see if redeem is running? "systemctl status redeem -l " will show you something like âactiveâ or âfailedâ near the top of the output.
Redeem is listed as active running but weird output as well
CGroup: /system.slice/redeem.service
`-301 /usr/bin/python /usr/bin/redeem
Apr 03 20:33:06 kamikaze redeem[301]: load_entry_point(âRedeem==1.1.5â, âconsole_scriptsâ, âredeemâ)()
Apr 03 20:33:06 kamikaze redeem[301]: File â/usr/lib/python2.7/dist-packages/redeem/Redeem.pyâ, line 568, in main
Apr 03 20:33:06 kamikaze redeem[301]: r = Redeem()
Apr 03 20:33:06 kamikaze redeem[301]: File â/usr/lib/python2.7/dist-packages/redeem/Redeem.pyâ, line 190, in init
Apr 03 20:33:06 kamikaze redeem[301]: stepper.set_decay(printer.config.getint(âSteppersâ, âslow_decay_â + name))
Apr 03 20:33:06 kamikaze redeem[301]: File â/usr/lib/python2.7/ConfigParser.pyâ, line 359, in getint
Apr 03 20:33:06 kamikaze redeem[301]: return self._get(section, int, option)
Apr 03 20:33:06 kamikaze redeem[301]: File â/usr/lib/python2.7/ConfigParser.pyâ, line 356, in _get
Apr 03 20:33:06 kamikaze redeem[301]: return conv(self.get(section, option))
Apr 03 20:33:06 kamikaze redeem[301]: ValueError: invalid literal for int() with base 10: âTrueâ
Yes, that looks like a case of expecting a numerical value and instead reading in a âTrueâ for that line⌠Double check your local.cfg file. And if youâve installed from the git repository, donât forget to copy configs/*.cfg to /etc/redeem (it wonât overwrite local.cfg) to have the proper syntax and values in those files which can otherwise cause issues.
This is the stock kamikaze image which was working while in pieces but now all back together I get no serial. The only difference is I have hooked up the end-stops. I think I will disconnect the end-stops and update the system files just in case.
So, got redeem all working again and motors moving. Weird issue, when homing the sliders only move up a bit then down but never all the way up to the end-stops. I keep homing it will eventually get to the top but then I can only move down about 10 and it wonât go further. Any tips on getting a Delta printer setup on the replicape?
Not to worry. I feel like such a numpty for choosing the wrong printer type. Need more coffee.
