So I bought Heekcnc today and I can’t manage to get the surface pocket operation to work. I’ve been creating a sketch and adding the surface component, but the post process always locks up.
Can anyone give me some advice on how to do a 3d operation?
Heekscam assumes your controller uses canned cycles Gcode. If yours does not, you can exclude them by editing the xml configure file
Not sure if this is your issue however
That doesn’t seem to be the answer… I’m having issues with the paths being generated.
