You’ll want to provide a more literal transcript, including a literal transcript of the error. A summary of a message you don’t quite understand is unlikely to result in a clear diagnosis.
Are these the documents you are following?
cut and paste the EXACT ERRORS you are seeing
in between two lines that contain exactly only
three single back quote characters each
This way we see them without interpretation and without formatting.
Yeah a copy and paste of the error codes, or a screenshot or whatever would be helpful. Also if we’re really running to problems post up your Marlin folder and I can download it and try and compile and see if I run into the same errors. If I don’t get errors compiling then it’s probably dependencies that are installed. If I do get errors then it’s probably in the syntax somewhere.
I have resolved most of the errors now (your correct response - missing dependencies), but I don’t yet understand this last one, not sure what I am missing, I don’t know the entry to point to a specific disk? I am assuming it is looking for the SD card, which I have in a usb port, or is it looking for my BTT oard and it’s usb port?
Error:
Building in release mode
Unable to find destination disk (Autodetect Error)
Please select it in platformio.ini using the upload_port keyword (Upload options — PlatformIO 5.2.0a4 documentation) or copy the firmware (.pio/build/LPC1769/firmware.bin) manually to the appropriate disk
I use the terminal instead of the platformio gui, so I’m using platformio run to build Marlin. I don’t have the board connected when I build. What have you set default_envs to in your platformio.ini file?
At least on Linux using platformio run on the command line, it built fine from your zip file.
... platformio run
Processing LPC1769 (platform: https://github.com/p3p/pio-nxplpc-arduino-lpc176x/archive/0.1.2.zip; board: nxp_lpc1769; framework: arduino)
Verbose mode can be enabled via `-v, --verbose` option
CONFIGURATION: https://docs.platformio.org/page/boards/nxplpc-arduino-lpc176x/nxp_lpc1769.html
PLATFORM: NXP Arduino LPC176x 0.1.1 > NXP LPC1769
HARDWARE: LPC1769 120MHz, 31.97KB RAM, 464KB Flash
DEBUG: Current (cmsis-dap) On-board (cmsis-dap) External (blackmagic, jlink)
PACKAGES:
- framework-arduino-lpc176x 0.2.4
- toolchain-gccarmnoneeabi 1.70201.0 (7.2.1)
Converting Marlin.ino
LDF: Library Dependency Finder -> http://bit.ly/configure-pio-ldf
LDF Modes: Finder ~ off, Compatibility ~ strict
LibraryManager: Installing U8glib-HAL
Downloading...
U8glib-HAL @ 0.4.1 has been successfully installed!
Looking for TMCStepper library in registry
Found: https://platformio.org/lib/show/5513/TMCStepper
LibraryManager: Installing id=5513 @ >=0.6.1,<1.0.0
Unpacking [##################################--] 94%
Unpacking [##################################--] 95%
Unpacking [##################################--] 96%
Unpacking [##################################--] 97%
Unpacking [###################################-] 97%
Unpacking [###################################-] 98%
Unpacking [###################################-] 99%
Unpacking [####################################] 100%
TMCStepper @ 0.7.1 has been successfully installed!
LibraryManager: Installing Adafruit NeoPixel
Downloading...
Adafruit NeoPixel @ 1.3.0 has been successfully installed!
LibraryManager: Installing SailfishLCD
SailfishLCD @ 0.0.0 has been successfully installed!
Found 6 compatible libraries
Scanning dependencies...
Dependency Graph
|-- <Servo> 1.0.0
|-- <LiquidCrystal> 1.0.0
|-- <U8glib-HAL> 0.4.1
|-- <TMCStepper> 0.7.1
|-- <Adafruit NeoPixel> 1.3.0
|-- <SailfishLCD>
Unable to find destination disk ([Errno 2] No such file or directory: '...')
Please select it in platformio.ini using the upload_port keyword (https://docs.platformio.org/en/latest/projectconf/section_env_upload.html) or copy the firmware (.pio/build/LPC1769/firmware.bin) manually to the appropriate disk
Compiling .pio/build/LPC1769/src/src/HAL/LPC1768/DebugMonitor.cpp.o
Building .pio/build/LPC1769/firmware.bin
Advanced Memory Usage is available via "PlatformIO Home > Project Inspect"
RAM: [=== ] 25.5% (used 8364 bytes from 32736 bytes)
Flash: [== ] 22.2% (used 105388 bytes from 475136 bytes)
========================= [SUCCESS] Took 80.89 seconds =========================
LPC1769 SUCCESS 00:01:20.891
Therefore, this line from your build log looks like it is relevant:
*** [Marlin\src\HAL\LPC1768\DebugMonitor.cpp] D:\Downloads\Marlin-2.0.vs\Marlin-2.0.x\.pio\build\LPC1769\.sconsign37.db.dblite: No such file or directory
@Eclsnowman want to try on Windows and see whether you can reproduce this problem?
I see No such file or directory in your build log so it surprises me that you found an old file by that name. I wonder if you could just delete the whole .pio directory and try again?
What I’ll do later today once I get some free time is try and set up a clean Marlin that I can get to compile. Would you be able to confirm all the hardware you have: steppers, drivers, LCD, travel limits from before, etc:
That way I can go through and confirm your config against one I’ve set up in the past for my skr v1.3 Eustathios and just make the changes for your setup.
I have most of the details in the configuration.h file in the zip. I transferred the setting from my smoothie config file. I am really trying to learn the environment of visual studio code and the marlin at the same time, probably not a great combination. But my thought was to get a solid compile and then add additional features in…Once I get a successful compile, I have a bltouch to add, and I wanted to go without the X and y End stops.
Okay, . I cleaned out all the marlin, platform io and Visual Studio code files from my computer.
I reloaded everything and did a simple compile for the mega. Successful.
I followed the marlin page on identifying and updating configuration.h for the BTT SKR 1.4 Turbo board. Made the change to platformio.ini to reflect the board. Successful.
I am going back to make the customization for my Herculien. Looks like I just did not get a clean install in the beginning.
Thanks to you both for looking at this. I’ll hopefully report back a successful build after church today.
