Question on Electrical conductivity of coolant. I’m currently using the distilled water + biocide + dawn recipe. This is giving me about 50us on a little meter I’ve got.
Distilled water reads about 2us, so the meter seems like it’s doing a good job. I’m assuming the dawn + biocide is what is raising it up to 50.
It’s getting cold and I need to add something to prevent the liquid from freezing. I’ve got some propylene glycol and I could add that. But I’ve also got some pre-mix RV antifreeze that I measured at 80us. 80 does not see like that much higher of a number, and certainly a lot less than the +400us I’ve seen listed for rv antifreeze elsewhere.
Is there some sort of maximum level of conductivity or is it ‘just keep it as low as possible’.
I like the idea of using the RV antifreeze as it’s much cheaper than the propylene glycol.
Unfortunately we do not know what an acceptable range is because we can’t easily model or test the phenomena. I know that more than 300 is bad news but don’t know what the lower limit is.
We also do not know what the long term effects of conductivity are.
So yes, keep it as low as possible. BTW many folks use aquarium heaters to keep their water from freezing.
I was using RV antifreeze and it was way above 300 and created a problem with my HVT!
I just use distilled water and algaecide. +1 for using aquarium heaters. That’s what I used last winter. I just set it to as low as possible (so it is well over freezing but not trying to keep it hot) and then make sure I’ve got the pump running the whole time, too. Fortunately, it doesn’t drop below freezing too often here (Seattle, WA area) so I just keep an eye on the nighttime temperature forecast and only turn it on when it looks like it will be necessary.
Thanks Guys. Guess I’ll just dump in the propylene glycoal and use the aquarium heater when it gets really cold and I’ll save the rv antifreeze for my water cooled spindle.
