I had been using jscut to generate gcode for my CNC router and recently decided to try lasercut. Unfortunately I am unable to run it on my linux machine for some reason. Can someone help me?
I am running this appImage:
laserweb-builder-v4.0.996-130-x86_64.AppImage
And after it runs a bit it then puts up a white page with the following error:
OpenGL won’t start. This app can’t run without it.
My openGL info is:
glxinfo |grep OpenGL |grep version
OpenGL core profile version string: 4.5 (Core Profile) Mesa 23.0.4-0ubuntu1~22.04.1
OpenGL core profile shading language version string: 4.50
OpenGL version string: 4.5 (Compatibility Profile) Mesa 23.0.4-0ubuntu1~22.04.1
OpenGL shading language version string: 4.50
OpenGL ES profile version string: OpenGL ES 3.1 Mesa 23.0.4-0ubuntu1~22.04.1
OpenGL ES profile shading language version string: OpenGL ES GLSL ES 3.10
So you need to run laserweb-builder in order to run lasercut? That sounds sus. Besides, laserweb is a Windows-only app IIFC
Correction: LaserWeb is a JavaScript front end(browser)and backend(web server). The nodeJS can run the backend while a modern browser runs the client side so platform neutral.
Looks like LaserCut is a Java based application so it runs on anything which has a Java runtime with GUI support. No idea why you’d try to run LaserCut by running a laserweb build image.
Actually, Laserweb is a Javascript application and runs in your web browser. It’s /really/ cross platform (*)
It has been packaged several ways; into a Electron Image for use on windows, as an appimage for linux, as a NPM package and as Docker images.
All the above are now elderly and starting to break. I dont have the skillz, time or mental space to fix this.
Currently I run Laserweb by running lw.comm.server (cloned from git) in NPM, then browsing to localhost:8000 in my browser. I’m on Fedora 40 and WebGL ‘just works’.
I run this on a PI attached to the machine via USB serial; and this gives me ‘OctoPrint for my CNC’,
(*) So long as your browser handles WebGL correctly, not all do, and not all distro/desktop/browser combinations work.
The fact that OpenGL errors appear above doesnt surprise me; afik the appimage bundles a web browser. Probably a really elderly one.
Thank you both for letting me know I am looking for laserweb vs laswercut I’ll take a look at the laserweb page and try to get that working on my localhost and report back
So interesting enough, I tried running the appimage on 2 other linux machines with the same distribution and it worked fine. I am going to see if I can figure out what is different between the machines drivers/openGL installations. (It’s funn because all 3 machiens are running the same distro, so it must be something unique for what gets installed for the one machines video card) If I figure it out, I’ll post back the results for anyone else that has this issue.
It seems to run ok in the web browser but I still was not able to run it on the one machine as an appimage. My best guess is the driver for the video card in linux does not support it.
