LaserWeb information
On the About page, I see that I have:
- Frontend version: _4.0.999
- Backend version:4.0.138
My settings are:
Generic GRBL
GCODE start G21 G90 M4 S0
Problem description
When I set the laser power of a cut or engrave to (for example) 50% , I expect GCODE file generated to set the s code to S500 , but instead it sets it to S0.5 i.e. 0.5%
I have used the same input svg file (a simple square) in lightburn to create GCODE and that correctly outputs S500
System description
- My machine is a diode laser Atomsack K20
Have I missed a setting I should have changed ?
Thanks for your Help
Alan
