I’m having some trouble with printing PETG. I will be printing and it will just stop extruding filament. It seems to be pushing but is grinding like it can’t push filament, almost like it’s not hot enough. I’m printing PETG at 260 degrees.
Is .5 amps enough for my extruder stepper motor?
Do I need to do some PID tuning? What commands do I need to use on an Azteeg X5 Mini V3?
Is your temp fluctuating during the print? If not, PID tuning will gain you nothing. I would try turning the motor current up a bit. I typically run the NEMA17 on my bondtech at around 0.8-1A.
Do you have a cooling fan coming on right before the jam? Could be a drop in temp with the fan blowing on the heater block. I also try and limit cooling with PETg to as low as I can go and still achieve decent overhangs
