Originally shared by Petr OK1RP
New recharchable AA cells battery case for dualband handheld is printed. Metal contacts to be installed and it will be finished and tested.
Nice! Would you please post the result and, if possible, the building process?
There’s something interesting going on with the perimeters of the top part of the print.
Are you extruding with a line width equal to your nozzle diameter? Otherwise I would say you are under-extruding.
The infill-perimeter overlap also seems inadequate but that could also be a symptom of under-extrusion.
@Neil_Darlow Thanks Neil! I am real beginner and it is my 4th printing at all so I have to learn all about. I see what you mean. Should I increase the temp of nozzle?
In fact I did not changed anything on printer just assembled it and running…
I would look into calibrating your extruder. If you do a search on your printer model combined with extruder calibration you should find some appropriate procedures.
Very beautifull print !! Use you cura ??
