Originally shared by Luis Diaz
Hi!
I’ve been able to put everything together and test the car… But more problems!
I’ve less stearing to the right compared to left. What can I do tl fix this?
@Daniel_Noree please spread your wisdom
Thanks!!
Hi!
Thanks!!
Do you have direct linkage connection to servo? Or can you add an adjustment “screw” or similar. Or reposition servo arm some.
Theres a few things that could cause this. First do you have the servo horn vertical. Is the trim on the TX off center?
@TeamDogoman_Rc yes, I have the servo horn vertical and the trim on the tx starts at the very center.
I had to change the servo rotation to make it work by hacking the servo
Could you post a pic? That would help…
