Originally shared by Jimmy Edwards
I received my #Replicape !!!
The package looked scary when it arrived in the mail…
But the Board shows no sign of damage. She is a beauty.
I’m so glad that I bet on Elias Bakken and the “thing” crew.
Now I have to get to work on building my 3D printer.
Fan-freaking-tastic James! Yes, it did look busted, but none of the packages have had any faults so far! If you want to use the Thing Image, make sure you do a
opkg update
opkg install replicape-device-tree
from the fresh image.
Thank you So Much for the VooDoo that you do Elias !!! I know that it takes a LOT of work to go from VaporWare to HardWare.
Yeah, my box looked the same but all was intact also.
@Jimmy_Edwards Any progress with your cape?
I’ve come down with a severe case of summer time procrastination. I’m plugging away on the assembly of a printer frame. As soon as I get the Stepper motors mounted I’ll fire up the Cape and try to make things move. This is more of a winter project, something to do when stuck inside.
