Orange Pi Zero Art-Net 3 Pixel controller - 4 Universes
#orangepi #orangepizero #artnet #dmx512 #pixel #neopixel #ws2811 #ws2812 #ws2813 #ws2815 #sk6812 #apa102 #apa102c
@Arjan_van_Vught how many leds?
@Yves_BAZIN 4 universes = 680 RGB led’s
@Arjan_van_Vught how many universes can it handle ?
@Yves_BAZIN 4 universes (Art-Net 3)
Hi…If you require bidirectional data flow I.e. rdm or you wish to use it as a slave and master you will need a little programming for deciding when to send / listen . If you just wish to send data use the simplified designs from that page. You will need to tell ola to use the UART on the RPI instead of the USB as well as setting it up to send at the correct baud rate. I am lookingat using a RPI to take art net from ola and sent out spi to led pixels. So a very similar approach could be used. There is a project called light pi which I believe is already doing this. Have a quick search and you should find some more info about directing ola to something other than USB.
