Ramps1.4 w/ Arduino Mega + Marlin. Raseter codes generated by LasweWeb. Run though SD Card. Still issues running larger codes over USB, may be its slower control board, but SD Card works great!
@Scott_Thorne Thanks buddy. You know I printed this last night and I got bit busy after I started printing, and about half way I took quick look at it and My Mind = Blown!
@Sean_Cherven Actually Its like some kind of sync issues. USB probably talking too fast to Ramps and its buffer it getting full and then it does all weird spyderweb thing on top of your actual print / Cut
+Peter van der Walt What Pixel / Dot size to keep the raster same as original picture? What dpi should be the original Pic?
I uploaded 6x8" 300 dpi pic for rastering and its taking loooooooong to create the codes. I guess next time I should go with 72dpi.
