Okay so I’m going to try and describe my problem as best as possible.
Im using Bigfoot SPI drivers on my X5 GT and the second extruder refuses to move. What I think may have happened is that particular channel has been fried but im not sure how to tell.
I’ve tried changing the pin’s in the config file and it still wont move. Im trying to see if its a wiring issue now but in the meantime, does anyone have any ideas?
try wiring the motor that doesn’t run to one of the drivers you know is working to test if its fried or not. If it works then chances are something is, if it fails then it must be a bigger issue(bad motor, wiring, config, etc.) first the easy test then worry if its bigger than that
well next best thing to do would be to post pics of wiring, your config file settings, and maybe something will stand out. Also screenshot your LW settings, helps to know.
No worries. I’ve been looking into building a laser engraver/cutter. I’ll get those setting posted here in a bit. @raykholo I’ll get you pictures of those driver’s soon.
