I have the latest firmware and config file setup with my board. Currently I have XYZ motors working as expected.
But concentrating on the X axis homing. The homing in Pronterface only moves the Head to the left a few mm when I clicked X home. Moving otherwise seems to work fine. If I keep clicking Xhome eventually it does hit the switch and then moves if you millimetres to the left, presumably switch is released.
But this seems rather peculiar because X should continue to move to the right until it hits the switch and then stop moving.
endstops_enable true # The endstop module is enabled by default and can be disabled here
#corexy_homing false # Set to true if homing on a hbot or corexy
!alpha_min_endstop 1.24^ # Pin to read min endstop, add a ! to invert if endstop is NO connected to ground
#alpha_max_endstop 1.25^ # Pin to read max endstop, uncomment this and comment the above if using max endstops
alpha_homing_direction home_to_max # Or set to home_to_max and set alpha_max and uncomment the alpha_max_endstop
alpha_min 0 # This gets loaded as the current position after homing when home_to_min is set
alpha_max 200 # This gets loaded as the current position after homing when home_to_max is set
My switch is NO to GND so I put the ! in !alpha_min_endstop ?
I home to max as I need it to move to the right to hit the switch…
#alpha_min_endstop 1.24^! # Pin to read min endstop, add a ! to invert if endstop is NO connected to ground
alpha_max_endstop 1.25^! # Pin to read max endstop, uncomment this and comment the above if using max endstops
