I have been trying to add a relay(5v and 12v) to my Nvum controller to run my dust collector and have had no luck getting it to work. Can anyone help??
Iot Relay - Enclosed High-Power Power Relay for Arduino, Raspberry Pi, PIC or WiFi, Relay Shield https://www.amazon.com/dp/B00WV7GMA2/ref=cm_sw_r_cp_apa_i_gq4oEbXEJXQTX
Welcome, Dan.
I am not familiar with a Nvum controller. Can you point us somewhere that has more info. on the controller?
What have you tried so far?
I’m sure we can help … with the right output from the controller the controllable power strip @HalfNormal suggests could work or you could build your own equivalent.
I have been working on it again today. I am new to 5v relays. Is it normal to need a 5v signal to trigger it?
Is this what you have?
That is the one I have
Are you using the MACH3 software to control the board?
If it seems that there is a mist/flood relay you can use. It’s just a questions of figuring the pin configuration in the software
This video is suppose to show you how, but it’s not really clear but you might be able to piece it together
Thanks Ned. I will give that a try. I will let you know if it works
Dan
can you provide a wiring diagram/schematic of how you have it wired?
