I don’t think the OP know the meaning of series or parallel circuits. Seeing what was drawn I don’t believe the OP knows what an electrical wire actually does so this really is more of an effort of literal steps. ie cut the blue wire, expose the copper of the 2 cut ends, connect the copper to the 2 terminals/connections of the Amp meter, etc.
It scares me when I see someone draw a circuit like what was drawn and is inside the electronics bay of a laser cutter.
hahaha… i do understand what and how circuits work… and i drew the circuit on microsoft paint… just because i don’t use fancy software to draw a schematic diagram, it doesn’t mean i’m an idiot.
We need to step back and understand what you are trying to do?
If you are just trying to add a 30 ma laser current meter to your new machine, you simply add it in line with the blue wire.
But your previous post asked how to add a laser test button…
Now your latest drawing shows the Main Control Panel that if it matches the photo is a digital control panel. That panel already has a laser test button so why are you adding one?
I do not see any reason to change any of the wirings of this new machine if you are just adding a meter. Just add it in line with the blue wire? If you need a detailed explanation of how to add it inline let me know.
AJ, you drew a circuit with an amp meter in it AND you included a circuit trace bypassing the amp meter.
Nobody called you an idiot, just lacking the understanding of electrical circuits. Terms like “in series” are terms used in describing certain ways of connecting circuit components and you seemed to have missed that.
Yes, because @donkjr said:
The milliamp meter is wired in series with cathode and ground. Specifically the FG ground pin on the LPS.
“laser cathode ----->+METER------> FG pin on LPS.”
that is why i asked again multiple times for clarifications… it was a simple misunderstanding because (which i later realised) Don was under the impression that my LPS did not have an L- … and I was trying to figure out how (with his explanation) put the whole thing together with the L- on my machine…
No it is not, only thing in the picture that’s connected is the ammeter and the water temperature gauge. The scheme is my reference to what the original wiring and layout is before i hack it all up.
Would i really need one since the original panel did not come with one?
Your right I see that your original digital panel does not have one. The digital panels I have seen have one. Evidently another ugly change in that panel’s design.
Without the digital panel, you need a function that enables/disables the laser.
Everything you need is on the drawing I gave your for your supply including a Laser Switch (laser enable) and a Laser test both of which you need if you are replacing the digital panel.
I suggest modifying this drawing to show your actual wiring that way we will stay on the same page :).
hi I enter this discussion as I am waiting for the same machine, starting from the last scheme posted for the conversion to analogue if I wanted to change the m2 nano card with a dlc 32 v2,2 that I have at home for other things besides having the drivers and maybe an external 24v 10A power supply how should I make the connections to exploit the pwn in ligthburn?
on the circuit above we quickly tried to make a mks dlc 32 2.1v work instead of the m2 nano but we cannot go beyond 13mA with the tube, all having connected:
G-WP
-Spingle / TL
gnd mks-G
so the machine in lightburn works but with 100% power it shoots only at 13ma while with M2 nano it reaches 100% at 23ma what am I wrong?
