New project. 3hr print time, 36cm wingspan, 55g dry weight.
Are there files available?
I think the power to weight ratio should be just about right.
It would take a better flier than me to hang on to that thing.
that looks cool as hell! just R/E? where do you put the battery? also are you using a particular airfoil on the wing?
Files will be on thingiverse in a few weeks after ive completed some testing, im hoping just rear elevons will do the trick. Not sure what the airfoils is called but its a flat bottom and like standard streched tear drop. 1 wall completely hollow with one 1mm I-beam type thing for strength. And there is a slit for a battery strap where the clamp is holding the plane.
