New issues to solve! Yeah!
I have solved the issue with my x and y home. The issue turned out to be my home made adapter for the ribbon cable. There were 2 ground wires in it that needed to be wired together on my adapter and fed out to the controller. I have 2 more issues to solve and then I will be cutting.
The laser does not fire when I send gcode to it. I am using gcode generated out of inkscape firing on command M03. I am not sure if I need to set something on the config for that or not. I am using pin 3.26 on the Azteeg mini x5 to fire and running that through a 3.3v to 5v bidirectional logic level converter out to L on the powersupply.
If I hold down the test button I can etch. I noticed that the cut is backwards and upside down. I’m sure there is a way to solve this. Do I need to invert the X and Y direction in the config file?
Thanks for all your help
