Need some help on MOSFET for Heat Bed/ Config file
So I had it setup with a SSR but after 2 years it burt out, I think the 2.5 Big mosfet on the card also went out, shows 12 volts on it all the time.
(24 Volts Heat Bed only)
So rechecking the docs I see there is now a way to run in SSR mode
So I got this Wangdd22 3D Printer Parts Heating Controller MKS MOSFET for Heat Bed/Extruder MOS Module Exceed 30A Support Big Current
from Amazon
To replace the SSR If I read right it’s better then a SSR??
I set it up on pin 2.5 and the ground next to it
(had it on 2.4 but that is the cooling fan)
But having a hard time understanding the code in the config file …
Here is what I have (I think all wrong)
the only way I can get it to work was to set “temperature_control.bed.heater_pin 2.5”
does not seem right…
# Delta Geometry # --------------------------------------------------------------------- arm_solution linear_delta arm_radius 133.0899 arm_length 300.0000
Speeds
default_feed_rate 15000
default_seek_rate 15000
mm_per_arc_segment 0.25
mm_per_line_segment 5
delta_segments_per_second 200Arm solution configuration : Delta robot. Translates mm positions into stepper positions
alpha_steps_per_mm 160
beta_steps_per_mm 160
gamma_steps_per_mm 160Planner module configuration : Look-ahead and acceleration configuration
acceleration 1000
acceleration_ticks_per_second 1000
planner_queue_size 32
junction_deviation 0.01Endstops
endstops_enable true
delta_homing true
alpha_min_endstop nc
alpha_max_endstop 1.25^
alpha_homing_direction home_to_max
alpha_min 0
alpha_max 0
alpha_max_travel 670
beta_min_endstop nc
beta_max_endstop 1.27^
beta_homing_direction home_to_max
beta_min 0
beta_max 0
beta_max_travel 670
gamma_min_endstop nc
gamma_max_endstop 1.29^
gamma_homing_direction home_to_max
gamma_min 0
gamma_max 341.900
gamma_max_travel 670Homing
alpha_fast_homing_rate_mm_s 100
beta_fast_homing_rate_mm_s 100
gamma_fast_homing_rate_mm_s 100
alpha_slow_homing_rate_mm_s 10
beta_slow_homing_rate_mm_s 10
gamma_slow_homing_rate_mm_s 10
alpha_homing_retract_mm 0
beta_homing_retract_mm 0
gamma_homing_retract_mm 0Trim
alpha_trim -0.454
beta_trim -0.892
gamma_trim -0.806Stepper module configuration
microseconds_per_step_pulse 1
minimum_steps_per_minute 1200
base_stepping_frequency 100000Stepper module pins
currentcontrol_module_enable true
alpha_step_pin 2.0
alpha_dir_pin 0.5
alpha_en_pin 0.4
alpha_current 1.7
alpha_max_rate 30000.0
x_axis_max_speed 30000.0
beta_step_pin 2.1
beta_dir_pin 0.11
beta_en_pin 0.10
beta_current 1.7
beta_max_rate 30000.0
y_axis_max_speed 30000.0
gamma_step_pin 2.2
gamma_dir_pin 0.20
gamma_en_pin 0.19
gamma_current 1.7
gamma_max_rate 30000.0
z_axis_max_speed 30000.0Extruder module configuration
extruder.hotend.enable true
extruder.hotend.steps_per_mm 398.0
extruder.hotend.default_feed_rate 600
extruder.hotend.acceleration 500
extruder.hotend.max_speed 50
extruder.hotend.step_pin 2.3
extruder.hotend.dir_pin 0.22!
extruder.hotend.en_pin 0.21
delta_current 1Hotend temperature control configuration
temperature_control.hotend.enable true
temperature_control.hotend.thermistor_pin 0.23
temperature_control.hotend.heater_pin 2.7
temperature_control.hotend.thermistor EPCOS100K
#temperature_control.hotend.beta 3590
temperature_control.hotend.set_m_code 104
temperature_control.hotend.set_and_wait_m_code 109
temperature_control.hotend.designator T
temperature_control.hotend.p_factor 27.0
temperature_control.hotend.i_factor 1.5513
temperature_control.hotend.d_factor 120Heated bed temperature control configuration
switch.temperature_control.bed.enable true #
switch.temperature_control.bed.input_on_command M42 #
switch.temperature_control.bed.input_off_command M43 #
switch.temperature_control.bed.output_pin 2.5 # GPIO pin we connected to “+” on the SSR
switch.temperature_control.bed.output_type digital # just an on or off pin
temperature_control.swimming_pool_heating.heater_pin 2.5
temperature_control.swimming_pool_heating.pwm_frequency 20
temperature_control.bed.thermistor_pin 0.24
temperature_control.bed.beta 3974
temperature_control.bed.thermistor Semitec
temperature_control.bed.set_m_code 140
temperature_control.bed.set_and_wait_m_code 190
temperature_control.bed.designator Btemperature_control.bed.bang_bang true
temperature_control.bed.hysteresis 1.0
temperature_control.bed.p_factor 29.6
temperature_control.bed.i_factor .369
temperature_control.bed.d_factor 592Switch module for fan control
switch.fan.enable true
switch.fan.input_on_command M106
switch.fan.input_off_command M107
switch.fan.output_pin 2.4
switch.fan.output_type pwm
switch.fan.max_pwm 80temperatureswitch.hotend.enable true
temperatureswitch.hotend.switch fan2
temperatureswitch.hotend.designator T
temperatureswitch.hotend.threshold_temp 35.0
temperatureswitch.hotend.heatup_poll 15
temperatureswitch.hotend.cooldown_poll 60
switch.fan2.enable true
switch.fan2.input_on_command M42
switch.fan2.input_off_command M43
switch.fan2.output_pin 2.4
LCD Panel
panel.enable true
panel.lcd reprap_discount_glcd
panel.spi_channel 0
panel.spi_cs_pin 0.16
panel.encoder_a_pin 3.25!^
panel.encoder_b_pin 3.26!^
panel.click_button_pin 1.30!^
panel.buzz_pin 1.31
panel.back_button_pin 2.11!^
panel.encoder_resolution 4
panel.menu_offset 0
panel.alpha_jog_feedrate 6000
panel.beta_jog_feedrate 6000
panel.gamma_jog_feedrate 200
panel.hotend_temperature 225
panel.bed_temperature 80
panel.external_sd falseMisc System configuration
pause_button_enable false
return_error_on_unhandled_gcode false
leds_disable false
play_led_disable false
kill_button_enable true
kill_button_pin 2.12
dfu_enable false
msd_disable falseSerial communications configuration
uart0.baud_rate 115200
second_usb_serial_enable falsenetwork settings
network.enable false
network.webserver.enable true
network.telnet.enable true
network.ip_address 192.168.1.134
network.ip_mask 255.255.255.0
network.ip_gateway 192.168.1.1
If you have a Z probe, you can select a calibration strategy here
To calculate probe_offset_x/y/z:
- Heat up the hot end with filament loaded - and the print surface, if you have bed heat (this is important!)
- Jog the hot end down to the print surface, leaving a little dot of plastic
- Deploy the probe, jog it until the probe tip touches the dot
- Jog the probe up a little, remove the dot, jog it down until it triggers, and record the exact values in offset_x/y/z
PLEASE NOTE: probe_offset_x and probe_offset_y MUST be 0 if you want to use depth (Z) correction!
leveling-strategy.comprehensive-delta.enable true
leveling-strategy.delta-calibration.radius 135 # the probe radius
leveling-strategy.three-point-leveling.tolerance 0.01
comprehensive-delta.probe_smoothing 4 # if your probe has repeatability issues, this will probe multiple times & take the average (default 1)
comprehensive-delta.probe_priming 3 # if your probe keeps “creeping down”, this will run it the specified number of times to get it to settle
comprehensive-delta.probe_acceleration 100 # acceleration will be temporarily set to this during probing; original is restored later; 100 is a good value
comprehensive-delta.probe_offset_x 0 # distance between the probe and the nozzle
comprehensive-delta.probe_offset_y 0 #
comprehensive-delta.probe_offset_z 0 #Optional Z probe, see
probe endstop
probe_pin 1.28 # optional pin for probe
zprobe.enable true # set to true to enable a zprobe
zprobe.probe_pin 1.28!^ # pin probe is attached to if NC remove the !, default 1.29!^
zprobe.slow_feedrate 3 # mm/sec probe feed rate
zprobe.fast_feedrate 50 # move feedrate
zprobe.debounce_count 0 # set if noisy
zprobe.probe_radius 110 # how far out from bed center to probe
zprobe.probe_height 20 # how high the probe has to be moved above trigger elevation so that it won’t drag
zprobe.decelerate_on_trigger true # beneficial, unless your probe has no runout after it hits the trigger - in which case, set this to false
zprobe.decelerate_runout 0 # how many millimeters your probe can move past the trigger point; we’ll abort any decel > this long
Its the “Switch” part I’m having problems with
Imported from wikidot
