My laser is always working with full feed rate and full laser power. It doesn’t respect setting I provide before generating GCode. Although, in LaserGRBL it works just fine. The laser is Aliexpress bought machine. It’s 100x100cm with 10W laser. I have flashed controller with 1.1f Laseraxe firmware from T2Laser.
Just to make sure have you followed this https://github.com/LaserWeb/LaserWeb4/wiki/2.1-Initial-Configuration-GRBL-1.1
I did. And it doesn’t work.
can you post the gcode generated by laserweb or have you inspected it so it reflects your intended power and speed?
