My delta (AKA UglyBot) is slowly starting to form. So many silly mistakes made! Good times.
Whats in the picture :
3 x 100cm V-slots from OpenBuilds
One experimental carriage with printed wheels (as a placeholder until the back-ordered wheels from OpenBuilds arrive)
3 x 46cm weird 30x20mm t-slots that I salvaged from junk.
One experimental effector plate with 3 balls glued to bolts and an E3D.
Sure! Basically I duplicated the mini-v plate in plastic and use the excenter spacers from OpenBuilds to adjust tension. The excenters are not ideal for plastic but anyway it works. Well, the bearings are not great but OpenBuilds are sending me a new set without any fuss. I posted a picture of one axis here a while back and would love to link to it but it seems I am not familiar enough with google+ to find it again…
This is a video of my GT2 driven tower, using the printed carriage and openbuilds vwheels. It is running on makerslide here, but the same principal runs on 2040 VSlot too, I’ll video a leadscrew actuator I did for vslot. http://youtu.be/qPsmmmQ1G40
Notice the screws in the side, these are used to tension the wheels, you get the tension just right then tighten down the bolts that go through the wheels. My current Wolfstock uses Makerslide and the aluminum makerslide carriages and vwheels. The printed GT2 version is to reduce cost.
