My auto-level is made on the pressure sensor and operates below the bed level. The printer delta. When sent, G32 issues “Calibration failed to complete, check the initial probe height and / or initial_height settings”. I found out that the error is present only when calibrate_delta_endopps. How to fix?
Sounds like you haven’t set the right values for the max_travel settings.
Did not help installed max_travel 2x gamma_max. G32 E works without errors, and G32 R with an error.
