The two beam shots are on the left mirror 2 and on the right mirror 1 straight out of the tube. Any thoughts? Could it be dirt in the end of the laser tube?
Your tube has shifted to a higher Transverse Electromagnetic Mode (TEM). Looks like the TEM02 pattern. Nothing to do but get a new tube Iâm afraid.
Less than a month oldâšď¸ Thanks for the advice though. How could that have happenedđ¤
Tubes can go bad quick if there is no or insufficient cooling. Or itâs possible it was just a bad / marginal tube to start with.
I hope you have an analog milli amp meter on it and have not been setting the digital power level to anything more than 30% without knowing the real power settings.
A very fast way to kill your laser power is to over power the tube( stock tube should get no more than 18ma MAX ) and the second way is to let the water temp get above 25C( should be 20-22C ).
The best protection for your tube is:
- Use nonconductive coolant (distilled water)
- Put a temp control in series with the water protect circuit that disables the laser above the operating temperature
- Put a flow sensor in series with water protect circuit that disables the laser with lack of water flow
- Use a milliamp meter to control & monitor powerâŚ
Hopefully fitting the 30 ma meter tomorrow. need to get a flow sensor and temp control.
