Make me an offer: I have around 200 sets. Either for sale or exchange Aviation Plug Male & Female Wire Panel Connector 16mm 7 Pin GX16-7
Sets of Male and Female Plug + rubber sleeves for Female Plug
Pin Number: 7
Plug Diameter: 16mm
Ambient temperature: -50 ~ +70 ℃
Relative humidity: up to 98% at +40 ℃
Atmospheric pressure: up to 4,4 kpa
Vibration: vibration frequency 10 ~ 100Hz, acceleration 100m/s2
Impact: Frequency of 60 to 80 beats / min, acceleration of 250m/s2
Centrifugal: acceleration 250m/s2
Main technical characteristics
Rated voltage: 2 core /3 core/ 4 core- 400V, 5 pin /6 pin /7 pin /8pin- 250V Rated current: 5A
Contact resistance: (each contact pair)Less than 0.005 Ω
Insulation resistance: In normal conditions, not less than 1000MΩ; after constant warm tests, not less than 20MΩ.
Test voltage: (50Hz, RMS) In normal conditions, 2 core /3 core/ 4 core-1500V, 5pin/ 7pin -1200V,
After constant warm test, 2 pin/ 3 pin /4 pin <s>1200V, 5pin /7pin</s> 1000V
Separation Force: Each single foot separation force is 1-3N, total separation force is one and a half of the upper limit total amount of every single foot separation Force
Temperature Rise: at rated load, the contact of the temperature rise should not exceed +50 ℃ ambient temperature
Life: after the use of the plugs 500 times, the sockets and outlets should not be damaged
