I wonder if it’s possible to issue a command to load a completely different config file and then issue a reboot command to change the smoothie to a different configuration?
I suppose one could rename the config file and rename the alternate config to “config” and then reboot and then repeat to load the original config file, I was just wondering if there was an easier way?
Thanks
Imported from wikidot
