Like to make your own moving sculptures?
Here is the program for you!
Best yet, it is free!
Linkage Mechanism Designer and Simulator
http://blog.rectorsquid.com/linkage-mechanism-designer-and-simulator/
I found it a bit tricky to get started but have found it invaluable for envisioning linked mechanics. Somewhere I did a model for a k40 scissors lift?
Seems like the documentation link is broken
O got this
The document name you requested (/linkage.pdf) could not be found on this server. However, we found documents with names similar to the one you requested.
Available documents:
/linkage.zip (common basename)
/linkage.msi (common basename)
thanks !
Thanks for sharing
Following
Thanks for sharing.
