Layer height comparison on a stock Printrbot LC v1 with identical Slic3r settings except for the difference in layer height. Printed in Printrbot Bubblegum Pink PLA. I’ve been pretty satisfied with 0.32 mm and 0.2 mm layer height print quality. Probably need to play with retraction settings to clean up prints at lower layer heights.
I designed this print as a give away for 3D printer demos. It is a Boolean intersection between the 3D characters and a half sphere. It is intended to show off the layered nature of 3D prints. http://www.thingiverse.com/thing:100820
Considering the following possible upgrades: fan, GT2 belt, metric z-axis rod, aluminum bearing blocks to replace zip ties, aluminum print bed. Not sure how much any of the upgrades will create noticeable improvement in print quality.
