When working with Laser Fill Path operations in conjunction with multiple passes, the generated fill lines for each layer are identical in angle and position.
I wonder if it wouldn’t be benefitial for the quality of the result if the lines are slightly shifted, so that a line of a specific layer is placed between two lines of the layer below or even with a different angle.
Usually for “Laser Fill Path” you configure the tool diameter the same as your laser beam mark, so there should not be any visible dinstance between the lines.
There is no feature to shift the lines automatically on multiple path, but you could define multiple cam operations with different fill angles.
