I’m still getting my K40 set up and have been reading the manual for K40 Whisperer and watching some videos and I have a question.
You use red to outline the shape you want to cut. But assume you have several shapes in the same file, is there a way to specify the cut order? For example, say you want to cut out a doughnut shape. I feel you should cut the smaller inner circle first before cutting the larger outer circle. If the larger circle is cut first and the piece drops out the piece is no longer in the proper position to cut the inner circle. Just wanting to know the proper way to deal with this situation as I don’t see any mention of cut order in the stuff I have read or watched so far.
Thanks,
Carl
