just curious what number of steps everyone is using these days.
Some of each, with various levels of microstepping?
200 step, but really because I’ve tried 400 step and can see no visible difference in print quality…
I’ve used a 400 step motor for an extruder to help mitigate the torque falloff of microstepping, but really a better design was preferable.
Either is fine. I usually put a closed loop belt an some pulleys for gearing to increase torque for the y axiz that carries the x motor
i’d consider 400 steps if I was using 10mm Threaded Rod for my Z-Axis on my i3. At 1.5mm/rev on the thread count it may be tougher to precisely control the platform height. Not sure, but when I was doing industrial motion control we preferred higher counts for precision when dealing with coarse resolution hardware. Oh…and Opinions will differ across the board.
I’ve done both. The moire effect is smaller with 400 step motors.
You can still microstep
I’ve been doing 1/16 microsteps. They don’t eliminate the step detents.
with the right controller you can do any step size
