Jog via PS3 controller by mapping key. Thanks @Alex_Krause
Qué jefe!
Very nice. Does it work wirelessly too?
It would be cool to map the Start button to the Start job too.
edit: Just had another thought. Mapping Select button to be able to change the Jog ratio (0.1/1/10/100mm).
Mapping those other keys would need some magic from the Dev’s
I believe ps3 controllers are bluetooth
@Alex_Krause is correct. I had no battery on mine. Last time I used it was a couple of years ago while an intense capmaing of Modern Warfare
Now make the other stick power and we can laser cut and engrave by hand!
Laser etch a sketch
