Hi,
I have everything working, running a tinyG. I can send a file from Coolterm and it finishes. Everything Laserweb looks fine except when I start a job it will only execute several of the commands before it freezes. Could this be a flow control issue? At one point I thought it was not having CTS flow control set in the TinyG, but it still does it. How is flow control in Laserweb set: does it just inherit what the port was set up for?
Thanks and would appreciate any help.
Curt
LaserWeb information
On the About page, I see that I have:
- Frontend version: _____________
- Backend version: _____________
My settings are:
<go to Settings / Tools and save your LaserWeb Settings to a json file,
then open that file with a text editor and copy/paste the content here>
Problem description
When I _____, I expect _____, but instead _____ happens.
This problem is new since _______ | has always happened.
Here is sample gcode that demonstrates the problem
<paste the contents of the gcode segment here>
System description
My machine is a CO2 Laser | diode laser | mill | lathe | other
I have a NAME_OF_CONTROLLER_BOARD
It has NAME_OF_FIRMWARE version VERSION_OF_FIRMWARE installed
I connect via USB | Serial | Ethernet | WiFi using telnet | websocket
My computer(s) on which I run LaserWeb run(s) Linux version | Mac version | Windows version ________
Here is my configuration:
<paste the contents of your machine configuration file or $$ output here>
