Is there a way to have Smoothieware fire a laser without moving any axis? Our software supports a ‘pierce’ mode used for cutting thicker material, which amounts to a power-on with dwell, followed by a standard cut. The user can specify the power percentage and dwell time.
With GRBL, I would do this with:
M3
G1 F100 S xxx
G4 Px.x
M5
G0
resume normal cutting
I don’t see anything comparable in the Smoothie docs, as everything states the system must be moving to fire, with the exception of the fire command, but I’m assuming that does not go through the path planner.
If this is a normal operation for Smoothie I wouldn’t expect the config to matter, and I can’t have a requirement that users recompile for this anyway. It’s CNC 4-axis generic Smoo, if I remember right.
Does the fire command work with the planner? If I had a bunch of GCode mixed with fire and delay commands and pushed that through fast-stream, that would work? That’s what I’m looking for.
@LightBurn_Software You would precede it with M400 to sync it with the stream. I’m not sure fire command returns ok though so I could fix that if needed. You could also define a switch that simpl;y output the fire command on a defined M code. Sort of like a macro.
I’m looking for something that won’t require a specific config. The lack of OK is fine - I already track whether or not to expect a response for a given line of code. I’ll try the M400 - thanks.
I will say that if you made every command return an ok it would make some things much easier for development. For example, writing code to stream over IP to an RPI or ESP that then communicates with Smoothieware, those instances now need to know whether to expect an ok back or not. Using the islower() on the command string is ok, but it wasn’t obvious from the start that would work.
commands are not designed to be used in gcode files. most will not work if you stream them. fire maybe an exception. commands are only supposed to be used from the console.
It’s fine really. I have fix this in my own applications so I don’t have a stake in the outcome. I was suggesting a small change that would make it simpler for future developers.
