Is there a preferred location for mechanical endstops to be mounted? I’ve searched a couple of forums but can not find anyone talking about them or showing photos so I’m guessing it’s just make sure they are clear of any moving parts.
Look here and you’ll see the default location for K40 with MEC endstops
https://plus.google.com/+ArielYahni/posts/RgraoksVvbo
@Ariel_Yahni_UniKpty Thank you that will replace the x,y minimum/ 0,0 if set to top left but what about the maximum or do people not use these ?
Standard config ( so 99% users ) have it a top left only
Ok sounds good to me. Thank you
I swapped the y endstop from top to bottom so it aligns with open source software x.y start positions like inkscape. Alternatively i can flip the y axis in software
