In working through the SimpleWebServer.js from @Derek_Molloy new book, when I run the simple node.js test it launches on the USB interface 192.168.7.2 yet I was connected to my BBB via WiFi with a 192.168.1.x ip address and the USB disconnected . Where does the nodejs runner pick up the ip address? from the ifconfig? A configuration in cloud9, or ??? The SimpleWebServer.js does not run on the WiFi address, but if I plug in the USB it does run off it’s interface.
I’d rather use the WiFi and a power supply. Ideally the launch process would detect the active interface.
Note: I’m using a young release
root@beaglebone:/var/lib/cloud9# uname -a
Linux beaglebone 3.8.13-bone68 #1 SMP Sat Nov 22 02:12:03 UTC 2014 armv7l GNU/Linux
root@beaglebone:/var/lib/cloud9# cat /etc/dogtag
BeagleBoard.org Debian Image 2014-12-31
