Here is the code:
I tried compiling it in both Sloeber and the Arduino IDE, but go this from the Arduino IDE:
Arduino: 1.8.5 (Windows 10), Board: “WEMOS LOLIN32, 80MHz, 921600”
In file included from F:\sloeber-workspace2\fastLED_test_1\fastLED_test_1.ino:3:0:
C:\Users\dani\Documents\Arduino\libraries\FastLED/FastLED.h:14:21: note: #pragma message: FastLED version 3.002.001
pragma message “FastLED version 3.002.001”
In file included from C:\Users\dani\Documents\Arduino\libraries\FastLED/FastLED.h:65:0,
C:\Users\dani\Documents\Arduino\libraries\FastLED/fastspi.h:110:23: note: #pragma message: No hardware SPI pins defined. All SPI access will default to bitbanged output
pragma message “No hardware SPI pins defined. All SPI access will default to bitbanged output”
In file included from C:\Users\dani\Documents\Arduino\libraries\FastLED/platforms/esp/32/fastled_esp32.h:4:0,
from C:\Users\dani\Documents\Arduino\libraries\FastLED/platforms.h:29,
from C:\Users\dani\Documents\Arduino\libraries\FastLED/FastLED.h:52,
C:\Users\dani\Documents\Arduino\libraries\FastLED/platforms/esp/32/clockless_esp32.h: In instantiation of ‘void ClocklessController<DATA_PIN, T1, T2, T3, RGB_ORDER, XTRA0, FLIP, WAIT_TIME>::startOnChannel(int) [with int DATA_PIN = 18; int T1 = 60; int T2 = 150; int T3 = 90; EOrder RGB_ORDER = (EOrder)66u; int XTRA0 = 0; bool FLIP = false; int WAIT_TIME = 5]’:
C:\Users\dani\Documents\Arduino\libraries\FastLED/platforms/esp/32/clockless_esp32.h:410:13: required from ‘static void ClocklessController<DATA_PIN, T1, T2, T3, RGB_ORDER, XTRA0, FLIP, WAIT_TIME>::startNext(int) [with int DATA_PIN = 18; int T1 = 60; int T2 = 150; int T3 = 90; EOrder RGB_ORDER = (EOrder)66u; int XTRA0 = 0; bool FLIP = false; int WAIT_TIME = 5]’
C:\Users\dani\Documents\Arduino\libraries\FastLED/platforms/esp/32/clockless_esp32.h:314:26: required from ‘void ClocklessController<DATA_PIN, T1, T2, T3, RGB_ORDER, XTRA0, FLIP, WAIT_TIME>::showPixels(PixelController<RGB_ORDER>&) [with int DATA_PIN = 18; int T1 = 60; int T2 = 150; int T3 = 90; EOrder RGB_ORDER = (EOrder)66u; int XTRA0 = 0; bool FLIP = false; int WAIT_TIME = 5]’
F:\sloeber-workspace2\fastLED_test_1\fastLED_test_1.ino:60:1: required from here
C:\Users\dani\Documents\Arduino\libraries\FastLED/platforms/esp/32/clockless_esp32.h:432:41: error: ‘rmt_register_tx_end_callback’ was not declared in this scope
rmt_register_tx_end_callback(doneOnChannel, 0);
Multiple libraries were found for “FastLED.h”
Used: C:\Users\dani\Documents\Arduino\libraries\FastLED
Not used: C:\Users\dani\Documents\Arduino\libraries\arduino_69861
exit status 1
Error compiling for board WEMOS LOLIN32.
