I was recently quoted $75 from a local glass company to get a 420mm x 430mm x 1/4" of single pane window glass. I did ask them to chamfer the piece so I don’t cut myself handling it.
I feel that this is rather steep given that Home Depot is selling a 24"x24" for $10. How did you guys get the glass bed? Any recommendation on chamfer-it-yourself ?
@Tim_Rastall , do you mean tempered? What is the keyword I should ask for when I call around. Talking about calling around, I need the metal brackets for the bed mount too
I dug through the posts that @Eclsnowman made over the years and he mentions only getting a simple piece of window glass to go on top of the aluminum plate. Hmm.
I just went ti the local Ace Hardware store and asked for an 8"×8" piece of glass. I also asked him to hack a little bit off the corners. I don’t remember off hand exactly what I paid for 3 if them, but it was dirt cheap, like less than $20 for all 3.
And I’ve been using them for well over a year now. Currently using one on top of my heated aluminum bed and the probe is now sensing the aluminum underneath the 1/4" glass just fine.
I have had boro glass, and even higher temp neoceramic glass before. But currently I am using standard window glass. Avoid tempered glass, it is less ductile than standard glass and is more prone to cracking. The best trick is to avoid too much force CLAMPING the glass to the bed. On large pieces of glass the difference in compression around those metal binder clips was what I determined to be the cause of cracks using window glass on my old corexy.
I have been using standard window glass on HercuLien now for 6 months with no sign of issues. 1/4" thick is unnecessary and an added insulator from the heat spreader which isn’t good.
@Dat_Chu you can use 2"x2" in a pinch, that’s what I have on mine but I wanted the wheels further apart. The key is architectural angle because the inside corner is square. If you can’t find architectural angle just cut the 20x20 cross bars on the bed shorter so they don’t hit the inside fillet and skip the tapped holes into the end of the extrusion.
