I want to do some FFT with FastLED. I’ve only found code so old it calls for WProgram.h.
What’s some cool code? I’m running WS2812B strips.
I did this a while back:
https://github.com/atuline/FastLED-Demos/tree/master/fht_log
Note: Can’t recall much at all about it though, so good luck!
I’m using your FHT stuff, but want to do it with FFT too.
Right on. I think they have an FFT library as well, so you might want to give that a shot.
And you probably want a Teensy or other ARM based controller for that. You’ll not have much CPU left for your animations and FPS on standard Arduinos.
I agree with Thomas, I’ve tried FFT on AVRs, but had much better results on ARMs. Teensy has an amazing audio library with FFT: https://www.pjrc.com/teensy/td_libs_AudioAnalyzeFFT.html
@Andrew_Tuline
I cant get any FHT to work with Arduino/ ESP8266
@Jason_Coon
Any luck with fft or FHT on esp8266?
@Tommy_Sciano nope, haven’t tried FFT or FHT on the ESP8266 yet, and can’t seem to find any libraries. I keep meaning to try a MSGEQ7 with one, but haven’t yet. Could also use a Teensy with FFT, and stream the data to the ESP8266 over serial, maybe.
