I upgraded my 130W 1200x900 laser to Smoothie, and I’m delighted so far - definitely a huge upgrade over the Leetro controller.
I’m having trouble with laser power, however, it’s very confusing. I can’t seem to get the laser above 30% or so using S0.x commands.
Using a terminal to connect to Smoothie, I’ve been cutting lines using code like:
M3 0.2
G1 X10 F500 (I’m in G91 relative mode)
When I do this I monitor the current the laser is taking - it maxes out at about 10mA at about 30% power (S0.3). After that, increasing the S parameter has no effect.
laser_module_maximum_power is set to 1.0
FURTHER WEIRDNESS: When I use test mode, i.e.
fire 50
G1 X10 F500
I get much more power, it increases all the way to 50mA at 95% power.
Any tips?
