I received my manga screen 2 a few days ago and while it works great with mac and pc, i have problems getting it to display a correct image on Android.
As the documentation states the screen should work out of the box with an Odroid C2 running Android, i bought it for that particular reason.
While touchscreen and HDMI are working technically, the image appears 90 degree rotated and split in the middle, probably because of the 1080x1920 native resolution.
Theoretically i could build a custom rom, but i have no idea where to start.
I there a way to switch the resolution via serial interface?
Yeah, there should be a way to rotate the image on Android. I’ve forgotten what file to edit, but you should be able to Google that with no reference to the screen if you have it working in portrait mode.
@Elias_Bakken I think Phillipp knows this, I also tried switching it to 1080x1920. In either configuration Portrait or Landscape the image will duplicate 2+ times. This is only on SBC boards for me, if I connect to a computer it displays correctly. Can you show us what the config text should look like for a raspberry pi? Following the directions on the wiki is what gives me the result above.
