I need a adhesive foil to glue a veneer laser cut to an iphone. Does anybody have an idea where and how to find that ?
I buy copper foil from a firm on ebay, I use it for RF shielding, but I understand it’s used for stained glass work as well. I’d expect those outlets would selll aluminum tape as well.
Aluminum duct tape is used for sealing HVAC ducts and is normally found in a roll of 2"wide at your local homecenter.
Scott
thank you scott!
