I have Walter’s mini space invader carriage with two 24V blower fans and I just realized the pins on the Azteeg X5 mine v3 only has two fan outputs.
I have one input going to the hotend and I wired the twoblower 24V fans in parallel on the other output. The azteeg has a note that high amperage fans shouldn’t be used and I think mine apply since they are 0.16A.
I tried running them and they are extremely low speed, my voltmeter screen is damaged but it appears to be quite a low voltage.
Any suggestions? Are there alternatives to running the blower fans?
@Sean_B according to Roy there are pins in the EXP1 header that can be used for I/O. I’ve not figured out which ones yet as the wiring diagram doesn’t note them as either ‘I’ or ‘O’ but there is supposed to be a couple usable pins there
