I have one of the AliRubber silicone heated beds. I know the thermistor beta spec is 3950 and its resistance is supposed to be 100k at 25C. I set up the appropriate value in smoothieware config file and I’m getting readings of 130C at room temperature. The second thermistor also reads the same. Does anyone here have any idea what to try next?
The thermistors do respond with added heat (hand touching sensor area).
