I have been doing some more thinking,and i have a few ideas/questions.
Why not connect the vertical screws via a belt rather than having a stepper for each pillar? If you connect the pillars using a belt you could have more pillars with out adding steppers.
Why only 2 pillars? it would seem that 3 pillars would increase the rigidity and insure that the axis are more perpendicular.
Is there a reason for using 2 motors on an axis rather than a drive shaft? If you had 1 motor coupled to a drive shaft it would insure that both ends turn at the same rate.
Is there a reason why the gantry moves rather than the print? It seems to me that moving the gantry introduces allot of extra work.
I am thinking or remixing this to make it have all of the electronics up top, and all of the motors fixed but lowering the print. Reworking the z-drive to be belt coupled, reworking the x-z to be rod coupled, and a few other small tweaks.
