In my experience, lowering the temperature and reducing extrusion (by artificially raising the filament diameter to make the slicer think it needs to back down on the amount of incoming filament to push), you’ll have less fusing between the raft and the print. When using SkeinForge, you can also adjust the raft feed rate (adjust in 1-2% increments) to thin the interface down even more. When done right, the stuff just pulls off like velcro!
@Joseph_Chiu
Thanks to the pro tip. I’m going to try that. I have been playing around with the settings in Skeinforce but something in my settings have prevented the gcode from properly exporting to the SD cart. This sounds like a great tip.
@Shachar_Weis
Things don’t always arrive here and when they do, I get taxed over 20%. Shipping is very expensive and usually cost more than the product and I have no guarantee that I’ll get it. We do have masking tape and it’s off-white in colour over here. I’ll give that a try. Thankx
I use a white masking tape but it says 8 day. I suspect it is very close to the blue tape but with no color. This was the only tape i found that said 8 day all the others were common masking tape and this tape works really well. Try to look for that.
